Knowledge Base Article
Why does Mentor* ModelSim* simulation of the eSRAM Intel® FPGA IP generate X in the waveform?
Description
In the Modelsim* SE 2020 version software, you may see 'X' in the simulation of the eSRAM Intel® FPGA IP due to an encrypted code problem in the simulator.
Resolution
To work around this problem, run the simulation with the prior Modelsim* SE 2020 (e.g., Modelsim SE 2019.2) version.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.3.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
