Knowledge Base Article
Why does link-up fail after a Root Complex power cycle when using the P-Tile Intel® FPGA IP for PCI Express* in Endpoint or Upstream Port configuration with the Intel® Quartus® Prime Pro Edition Software version 22.1?
Description
Due to a problem in P-Tile Intel® FPGA IP for PCI Express* with the Intel® Quartus® Prime Pro Edition Software version 22.1, link-up failure will occur after a Root Complex power cycle when using the common clock scheme as Endpoint or Upstream Port mode.
Resolution
To work around this problem when using the Intel® Quartus® Prime Pro Edition Software version 22.1, implement a separate clock scheme.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 22.3.
Updated 3 months ago
Version 2.0
