Knowledge Base Article
Why does Intel Agilex® 7 FPGA F-Series, I-series, and M-series hang when performing recoverable configuration error?
Description
This behavior might be seen when Intel Agilex® 7 FPGAs AGF019, AGF023, AGI019, AGI023, AGI040 (ES), AGI041 (ES), and AGM039 (ES) try to perform recoverable reconfiguration due to configuration error if the nCONFIG signal is asserted less than 10 ms after nSTATUS signal goes low.
Refer to Intel Agilex® 7 Configuration User Guide (PDF) and Intel Agilex® 7 FPGAs and SoCs Device Data Sheet: F-Series and I-Series (PDF) for more details on the configuration timing diagram.
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software version before 23.1, ensure that the nCONFIG signal is asserted after more than 10 ms after the nSTATUS signal goes low.
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition Software version 23.1. Please contact the regional application engineer to download patch 0.11fw.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 23.2.
To get the patch file, file an IPS case to Application Engineering. ACS patch number 6944.
Updated 3 months ago
Version 2.0
