Knowledge Base Article
Why does HPS Coresight Trace Clock detection fail with Quartus® Prime Pro version 25.3?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3, the 'tpiu_trace_ctl' port is now tied to 0, causing a failure that did not occur when the port was left unconnected in previous versions.
Resolution
To work around this problem, perform the following steps:
- Run the IP Generation stage of the Quartus® compilation flow.
- Modify the generated file from IP Generation:
- Change in file: <ip_path>/hps_subsys/agilex_hps/intel_sundancemesa_hps_100/synth/agilex_hps_intel_sundancemesa_hps_100_*.v
Original:
Modified:
3. Continue the Quartus® Compilation flow from Analysis & Synthesis onward.
(Note: Do not run the IP Generation stage again)
This problem is scheduled to be resolved in a future release of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 6.0No CommentsBe the first to comment
