Knowledge Base Article
Why does hardware fail in O-RAN Intel® FPGA IP and eCPRI Intel® FPGA IP Example Design for Intel Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit (4x F-Tile) DK-SI-AGI027FA order code?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.2 and earlier, you may see the O-RAN Intel® FPGA IP and eCPRI Intel® FPGA IP Example Design failing when running on Intel Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit (4x F-Tile) DK-SI-AGI027FA order code.
Beginning with the Intel® Quartus® Prime Pro Edition Software version 23.2, Intel Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit (4x F-Tile), DK-SI-AGI027FES order code is obsolete and replaced by DK-SI-AGI027FA order code.
Hence, this problem is not observed at the DK-SI-AGI027FES order code.
[Failure observation]
  • No data transfer in hardware example, design testing
  • The hardware does not respond, and the system console terminates.
Resolution
This problem is fixed beginning with the O-RAN Intel® FPGA IP and eCPRI Intel® FPGA IP webcore version 23.2.
Updated 3 months ago
Version 2.0
