Knowledge Base Article
Why does generation of the DisplayPort Intel® FPGA IP UHBR10 (Ultra High Bit Rate 10) design example fail?
Description
When generating the DisplayPort Intel® FPGA IP UHBR10 (Ultra High Bit Rate 10) design example, the following error messages might be observed when the TX/RX Maximum link rate is set to 10 Gbps.
Error: dp_0: Neither "Simulation" nor "Synthesis" check boxes from "Files Types Generated" are selected to allow generation of Design Example Files.
Resolution
 To successfully generate the DisplayPort Intel® FPGA IP UHBR10 design example, turn on the Enable Video input Image port parameter.
Updated 3 months ago
Version 3.0
