Knowledge Base Article
Why does execution of the KEY_VERIFY JTAG instruction return 0x0 (hex) after the tamper protection bit has been programmed in Stratix® V, Arria® V or Cyclone® V devices?
Description
The JTAG instruction KEY_VERIFY is one of many non-mandatory JTAG instructions that are disabled when the tamper protection bit is enabled in Stratix® V, Arria® V, or Cyclone® V FPGAs. When executing a non-mandatory instruction like KEY_VERIFY, when the tamper protection bit is programmed, TDI points to the BYPASS register. Due to this, executing the KEY_VERIFY instruction when the tamper protection bit has been set will result in 0x0 (hex) being returned.
Resolution
To check if the tamper protection bit has been programmed in a device, shift a user defined pattern in when executing the KEY_VERIFY instruction and check that the TDO pattern received has a \'0\' shifted in,
Example, assume you shift in 0x15A (1 0101 1010 in binary). If the tamper protection bit has been programmed, since KEY_VERIFY=BYPASS, you should expect 0 1011 0100 where the last 0 is the content of the BYPASS register.
Updated 3 months ago
Version 2.0
