Knowledge Base Article
Why does elaboration of the JESD204B Intel® FPGA IP Nios® control design example fail, with a setting of L=1?
Description
Elaboration of an Intel® Arria® 10 FPGA JESD204B Nios® control design example with L=1 may fail in the Intel® Quartus® Prime Standard Edition Software v17.0 due to a problem with the Platform Designer interconnect with the reconfig_* interface, resulting in the Platform Designer not generating the source code files.
Other JESD204B Intel FPGA IP design example variants, including Nios control with L>1, RTL state machine control, generic Nios control, and generic RTL state machine control are not affected by this problem.
Resolution
To work around this problem, follow these steps:
  1. Locate and back up a copy of the following TCL file in your Intel Quartus Prime Software installation directory:
    ip/altera/altera_jesd204/src/lib/phy_adapter/altera_jesd204_phy_adapter_xs_hw.tcl
  2. Open the TCL file with text editor. Search for procedure xseries_avmm_adapter.
  3. Add $d_L == 1 OR condition check into the if statement below in the xseries_avmm_adapter procedure. There will be three occurrences of the if statements in the procedure:
    Before the change:
    if {[param_is_true RECONFIG_SHARED]
    After the change:
    if {[param_is_true RECONFIG_SHARED || $d_L == 1}
  4. Save the modified TCL file.
  5. Re-launch the Intel Quartus Prime Software, create a new project or re-open an existing project, and generate the Intel Arria 10  FPGA JESD204B design example.
This problem is fixed starting from the Intel Quartus Prime Software v17.0.1.
Updated 3 months ago
Version 2.0
