Knowledge Base Article
Why does Dynamic Phase Shift PLL reconfiguration fail when using the Altera PLL Reconfig megafunction on Stratix® V and Arria® V devices?
Description
When using the Altera® PLL Reconfig mega function for Dynamic Phase Shift, reconfiguration will not occur if the Start register is written immediately after the Dynamic Phase Shift register is written.  This will be evident because the waitrequest signal on the Avalon-MM interface will not be asserted.
This is due to a bug in the mega function fixed in version 12.1 of the Quartus® II software.
Resolution
To ensure reconfiguration takes place, there must be at least one mgmt_clk cycle between the first write to the Dynamic_Phase_Shift register and the write to the start register.
For more details on the operation of the Altera PLL reconfig MegaFunction, refer to AN661: Implementing Fractional PLL Reconfiguration with ALTERA_PLL and ALTERA_PLL_RECONFIG Megafunctions (PDF).
Updated 1 month ago
Version 2.0
