Knowledge Base Article
Why does Design Assistant not report a rule violation when my design uses a PLL locked signal as an asynchronous reset signal?
Description
Due to a problem in the Quartus® II software version 13.1 and earlier, Design Assistant does not report a rule violation when the locked signal of a PLL is connected directly to the asynchronous reset of a register.
When using the locked signal of a PLL as a reset, synchronize the signal to the destination clock domain to ensure correct timing analysis.
Resolution
This problem is scheduled to be fixed in the future release of the Quartus II software.
Updated 11 months ago
Version 3.0
