Knowledge Base Article
Why does d2h_tx_st_ready signal stick low when using R-Tile Multi Channel DMA FPGA IP for PCI Express*?
Description
Due to a problem in Quartus® Prime Pro Edition Software version 22.4 and earlier, you might observe d2h_tx_st_ready signal stuck low failure, and it can not be fixed by queue reset when using R-Tile Multi Channel DMA FPGA IP for PCI Express*.
Resolution
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition software version 23.4.
Updated 3 months ago
