Knowledge Base Article
Why does compiling the PHY Lite for Parallel Interfaces IP example design for Agilex® 3 FPGA C-Series and Agilex® 5 FPGA E-Series and D-Series generate invalid Fitter assignment warnings?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3, you might see that the PHY Lite for Parallel Interfaces IP example design compilations for Agilex® 3 FPGA C-Series and Agilex® 5 FPGA E-Series and D-Series generate a warning message on invalid Fitter assignments.
The following assignments are invalid and listed in the Ignored Assignments panel in the Fitter Compilation Report:
  • Can Relax Periphery to Core Hyper Register Constraint
  • TOP_FEEDBACK_DELAY_STEP
  • TOP_FEEDBACK_DELAY_SEL
  • BOT_FEEDBACK_DELAY_STEP
  • BOT_FEEDBACK_DELAY_SEL
Resolution
There is no workaround for this problem in the Quartus® Prime Pro Edition Software version 25.3. The invalid assignments can safely be ignored. The compilation and simulation results are valid.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.1.
Updated 4 months ago
Version 5.0
