Knowledge Base Article
Why does compilation fail for the F-Tile Ethernet Intel® FPGA Hard IP designs with Advanced Mode enabled?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.4, when Advanced mode is selected from the F-Tile Ethernet Intel® FPGA Hard IP GUI options, you might observe compilation failure.
This is because the Advanced mode is only supported for the following Intel Agilex® F-tile device OPNs:
  • AGIx040R39AxxxR0
  • AGIx022R31BxxxAA
  • AGIx027R31BxxxAA
  • AGIx027R29AxxxR3
  • AGIx023R18AxxxR0
  • AGFx022R31CxxxAA
  • AGFx027R31CxxxAA
  • AGFx027R24CxxxR2
  • AGFx012R24CxxxAA
  • AGFx014R24CxxxAA
Resolution
There is no workaround available.
For any other Intel Agilex® F-tile device OPNs, you must disable the Advanced mode to pass the compilation.
Updated 3 months ago
Version 2.0
