Knowledge Base Article
Why does changing the I/O count change the current consumption on other rails in Intel® MAX® 10 FPGA Early Power Estimator (EPE)?
Description
In Intel® MAX® 10 FPGA Early Power Estimator (EPE), under the I/O Tab's summary table, you may see the current consumption of each rail change as the I/O count for each module changes.
This is because the current leakage drawn from each supply is taken into account as the I/O count changes.
Resolution
To view the current consumption per module, refer to the values in the "ICCIO" column in the EPE.
Updated 3 months ago
