Knowledge Base Article
Why does avl_ready deassert after avl_write_req is asserted in my DDR3 and DDR2 SDRAM High Performance Controller II IP?
Description
When error correction code (ECC) is enabled, you will see avl_ready de-assert after avl_write_req is asserted increasing the Write latency. It is because the controller needs to wait for incoming data (deassert ready signal) and then decide if read-modify-write operation is required during command loading.
Resolution
This behavior will not occur if ECC is disabled.
This problem is fixed starting with the Quartus® II software version 12.0.
Updated 2 months ago
