Knowledge Base Article
Why does Arria®10 EMIF IP Example Design Generation Fail in Quartus® Prime Standard Edition Software version 22.1 for Windows*?
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 22.1 and later for Windows*, the Arria® 10 FPGA EMIF IP example design generation will fail with the following error message:
“Error: emif_0: An error has occurred when generating the simulation example design. See make_sim_design_errors.log for details.”
“Error: Failed to generate example design <design name> to: <example design directory>”
“Generate Example Design: completed with errors”
Resolution
An error encountered can be safely ignored during the simulation of Intel® Arria® 10 EMIF IP example design generation. The Simulation file sets for ModelSim-Altera® Edition Software and Aldec® Riviera-PRO™ are generated and contain the relevant design files to run the simulation successfully.
Additional Information
This problem is scheduled to be fixed in version 23.1 of the Quartus® Standard Edition Software.
Updated 11 months ago
Version 3.0
