Knowledge Base Article
Why does accessing an invalid register address on the AXI-Lite management bus of the MACsec Intel® FPGA IP cause the bus to hang?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.2, access to an invalid address on the AXI-Lite management bus of the MACsec Intel® FPGA IP will cause the bus to hang.
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software v22.2, do not attempt to access invalid (unspecified) register addresses on the AXI-Lite bus.
This problem has been fixed starting with the release of version 22.3 of the Intel® Quartus® Prime Pro Edition software.
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
