Knowledge Base Article
Why does a10_ref BSP compile show several unconstrained paths?
Description
In the Intel® FPGA SDK for OpenCL™ 17.0 BSP flow, you may see several paths or clocks remain unconstrainted.
Resolution
Users will need to comment out or remove the following lines in their top.qsf file:
# base revision compile SDC constraints only
set_global_assignment -name SDC_FILE base.sdc
set_global_assignment -disable -name SDC_FILE top.sdc
set_global_assignment -disable -name SDC_FILE top_post.sdc
It will be required to do another import compile after changing the QSF file
aoc --board <BSP_name> <kernel_name>.cl
This problem is scheduled to be fixed in a future release of the Intel® FPGA SDK for OpenCL™.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
