Knowledge Base Article
Why does “rg_overflow” assert when using the 100G Interlaken Intel® FPGA IP on the Intel® Arria®10 devices?
Description
Due to a wrong default parameter setting in the 100G Interlaken Intel® FPGA IP on the Intel® Arria® 10 devices, rg_overflow assert when you connect rx_user_clk to a 300 MHz clock, with 12.5 Gbps data rate.
Resolution
To work around this problem using the Intel® Quartus® Prime Software, modify the file <instance name>/synth/<instance name>.v as follows:
Change from:
.FAMILY ("Arria 10"),
.RXFIFO_ADDR_WIDTH (12),
.NUM_LANES (12),
Change to:
.RXFIFO_ADDR_WIDTH (13),
.NUM_LANES (12),
If the IP is regenerated, the modified file changes will be overwritten and must be edited again.
Updated 3 months ago
