Knowledge Base Article
Why do writes to an M20K fail after a Partial Reconfiguration?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.2 and later, you might see a functional failure when writing to an M20K RAM after Partial Reconfiguration. This problem only occurs in design targets an Agilex™ 7 F/I-Series devices and either of these conditions
  • The Compiler Optimization Mode is not set to Performance
  • The design has 2 or more abutting PR partitions that share the same clock.
Resolution
To workaround this problem, perform these options
  • Recompile the design with Compiler Optimization Mode set to one of the Performance options.
  • Ensure there is a separation (at least one row/column space) between abutting PR partition routing regions for the designs with more than one PR region.
Note: This restriction does not apply to Agilex™ 7 M-series production devices.
Related Articles
Why does my M20K RAM write fail after a Partial Reconfiguration operation?
Updated 2 months ago
Version 2.0
