Knowledge Base Article
Why do undriven input ports on a module in the golden design cause formal verification mismatches?
Description
This type of mismatch may occur when a port is undriven in the golden design.  In this case, Encounter Conformal assigns a "Z" value on the undriven port, but the revised design has a predefined value for that port assigned by the Quartus® II software.  Encounter Conformal detects that the designs are not functionally equivalent and reports a mismatch related to the ports.
In some cases, the problem occurs when you use VHDL instantiations of some Altera® megafunctions.  To avoid this problem, generate your megafunction variation in Verilog HDL.
Updated 1 month ago
Version 2.0
