Knowledge Base Article
Why do the TX and RX EQ parameter values set in the Analog Parameters tab of the F-Tile CPRI PHY Multirate FPGA IP GUI not take effect?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.1, the TX and RX EQ parameters you set via the Analog Parameters tab of the F-Tile CPRI PHY Multirate FPGA IP GUI will not take effect.
Resolution
To work around the above problem, you can configure the TX and RX EQ parameters by manually writing to the corresponding registers via the Avalon-MM interface.
This problem is fixed in 24.3 release of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
