Knowledge Base Article
Why do the simulation results from Simulink not match the results from ModelSim when using Dual-Port RAM blocks?
Description
You may experience this problem starting in Quartus® II's DSP Builder software version 11.0.  This problem is seen when using the Dual-Port RAM block and selecting the Memory Block Type of MLAB in the block parameters.
The problem is due to the "read_during_write_mode_mixed_ports" setting for synthesis and Modelsim® simulation being "OLD_DATA", as opposed to "NEW_DATA".
Resolution
To work around this issue, in the file alt_dspbuilder_dualram_xxx.vhd, change the parameter "read_during_write_mode_mixed_ports" from "NEW_DATA" to "OLD_DATA".
Alternatively, if your device family has embedded memory blocks that support mixed-port read-during-write mode of OLD_DATA, for example M9K in the Stratix IV devices, you can select this Memory Block Type in your Dual-Port RAM block.
Updated 2 months ago
Version 2.0
