Knowledge Base Article
Why do the GTS HDMI FPGA IP, GTS SDI II FPGA IP, and GTS DisplayPort PHY FPGA IP fail to compile when the RX and TX are combined in Dual Simplex mode with an empty TX channel?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, when using the Agilex™ 5 devices in Dual Simplex configuration mode, the RX channel must not be paired to an empty TX channel, or a compilation error will be caused.
Resolution
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 1 month ago
