Knowledge Base Article
Why do the Gen2 AN456 PCI Express High Performance Reference Designs have setup timing violations?
Description
You may see timing violations from and to the following nodes (setup and recovery).
*go_bit_r to *go_rcfg_r
*go_rcfg_rr to *ack_bit_r
These paths should be false.
Resolution
To work around this problem add the following constraints to the top level .sdc file:
set_false_path -from [get_registers *go_bit_r] -to [get_registers *go_rcfg_r]
set_false_path -from [get_registers *go_rcfg_rr] -to [get_registers *ack_bit_r]
Updated 1 month ago
Version 2.0
