Knowledge Base Article
Why do the EMIF Traffic Generator 2.0 configuration and status registers reset to their default values when the WORM mode is enabled?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 20.1, the EMIF Traffic Generator 2.0 (TG2) configuration and status registers (CSR) reset to their default values when Write Once Read Many (WORM) mode is enabled and a data mismatch is encountered.
Note that the WORM mode is disabled by default.
Resolution
This problem is fixed starting with the Quartus® Prime Pro Edition Software version 20.4.
Updated 1 month ago
Version 3.0
