Knowledge Base Article
Why do the clock frequencies in the ALTLVDS_TX megafunction different than those I enter in MegaWizard Plug-In Manager?
Description
Due to a problem in the Quartus® II software versions 10.0 and later, megafunctions generated with the ALTLVDS_TX MegaWizard™ Plug-In Manager may include clock frequencies that do not match what you enter for the What is the output data rate? parameter. This problem only affect Windows 64-bit operating systems.
To confirm that the Nominal VCO frequency for the ALTLVDS_TX PLL matches your data rate, follow these steps:
  1. In the Compilation Report, expand Fitter
  2. Expand Resource Section
  3. Check the PLL Summary
To work around this problem, perform the following steps:
  1. Close the Quartus II software.
  2. Append %QUARTUS_ROOTDIR%\bin64 to the User environment variable PATH.
  3. Restart the Quartus II software to use ALTLVDS_TX MegaWizard Plug-In Manager.
This problem is fixed beginning with the Quartus II software version 11.0.
Related Articles
Updated 2 months ago
Version 3.0
