Knowledge Base Article
Why do my transactions through the Arria 10 light weight axi interface function incorrectly in hardware?
Description
Due to a problem in the auto generated timing constraints in the Quartus® II software versions 15.0 update 2 and earlier, paths through the Arria® 10 light weight AXI interface are not correctly timing analysed which  could lead to functional problems in hardware.
Resolution
To avoid this issue comment out the following timing assignments from the *altera_arria10_interface_generator*.sdc file.
set_false_path -through [ get_pins -compatibility_mode *fpga_interfaces|hps2fpga_light_weight*aw_ready]
set_false_path -through [ get_pins -compatibility_mode *fpga_interfaces|hps2fpga_light_weight*aw_valid]
set_false_path -through [ get_pins -compatibility_mode *fpga_interfaces|hps2fpga_light_weight*w_ready]
set_false_path -through [ get_pins -compatibility_mode *fpga_interfaces|hps2fpga_light_weight*w_valid]
set_false_path -through [ get_pins -compatibility_mode *fpga_interfaces|hps2fpga_light_weight*ar_ready]
set_false_path -through [ get_pins -compatibility_mode *fpga_interfaces|hps2fpga_light_weight*ar_valid]
This problem is scheduled to be resolved in a future release of the Quartus II software.
Updated 11 months ago
Version 3.0
