Knowledge Base Article
Why do my data send to NOR Flash incorrect when I am using OPCODE command in the Stratix® 10 Serial Flash Mailbox Client IP?
Description
When using the Stratix® 10 Serial Mailbox Client IP, you will observe incorrect data being sent to the flash when you are sending data using the WRITEDATA_0 and WRITEDATA_1 register. This is because the byte ordering is in little-endian format. This will be the same as performing read-data operation.
Based on the SPI interface protocol, the most significant bit (MSB) is being sent or received when the data is transmitted. So each byte will be stored from the least significant bit (LSB) to the MSB of the READDATA_0, READDATA_1, WRITEDATA_0, and WRITEDATA_1. In other words, the data in the register will transmit the LSB byte to the MSB byte of the read or write data register.
Resolution
To resolve the problem, you will need to reverse the byte ordering of the 4 byte data on the WRITEDATA_0 or WRITEDATA_1 register
For example- 4 byte of data "0x11223344" is actually "0x44332211".
