Knowledge Base Article
Why do IO Cell registers in my design show as being unused in the Resource Property Editor even though they are being used?
Description
Due to a problem in the Quartus® II software versions 12.0 Service Pack 1 and earlier, IO Cell registers may appear to be unused (gray color) in the Resource Property Editor even if they are being used.Resolution
The control and data lines connected to a used register are correctly highlighted (blue color) which indicates whether the register is used or not.
This problem is fixed beginning with the Quartus II software version 12.1.
Updated 1 month ago
Version 3.0No CommentsBe the first to comment
