Knowledge Base Article
Why do Intel® FPGAs fail to configure when using Cypress S25FL-L flash for Active Serial configuration?
Description
Intel® FPGAs may not configure successfully when using the Cypress S25FL-L flash as Active Serial configuration flash memory and when the JIC programming file was generated with Cypress flash selected as the configuration device.
This is because the existing Cypress flash selection (S25FL) in the Convert Programming File or Programming File Generator window in Intel® Quartus® Prime software is based on the Cypress S25FL-S flash. This selection is incompatible with the Cypress S25FL-L flash.
This is also applicable when selecting Cypress in the Programming Flow Template in the Generic Flash Programmer.
Resolution
To work around this problem:
Updated 3 months ago
Version 2.0
