Knowledge Base Article
Why do I see zero value from chip_id[63..0] when reading the unique chip ID in Intel® Stratix® 10 devices?
Description
You may encounter the Intel® FPGA S10 Chip ID IP core intermittently failing where the output chip_id[63..0] will return all zero in Intel® Quartus® Prime Pro Edition Software version 17.1 (including Update 1 and Update 2).
Once failed, the Stratix® 10 device must be power cycled to recover reading the unique chip ID value.
Resolution
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 18.0.
Updated 3 months ago
