Knowledge Base Article
Why do I see "X"s on my Reed-Solomon II encoder outputs?
Description
Due to a problem with the Quartus® Prime version 15.1 software, you will see this behavior if you instantiate more than one Reed-Solomon II (RS-II) IP core in your design.
Resolution
The problem occurs because the msim_setup.tcl file (or the equivalent for your simulator) compiles both instances into the same library.
To work around this problem, edit the tcl script to add a new library, and move one of the instantiations to that library.
For example you may see the following lines:
ensure_lib ./libraries/_highspeed_rs_enc_151/
vmap       altera_highspeed_rs_enc_151  ./libraries/altera_highspeed_rs_enc_151/
eval  vlog -sv "/hs_rs_248_216_enc/altera_highspeed_rs_enc_151/sim/altera_highspeed_rs_enc_lagr_pkg.sv"  -work altera_highspeed_rs_enc_151
eval  vlog -sv "/hs_rs_248_232_enc/altera_highspeed_rs_enc_151/sim/altera_highspeed_rs_enc_lagr_pkg.sv"  -work altera_highspeed_rs_enc_151
eval vsim -novopt -t ps -L work -L work_lib -L altera_common_sv_packages ... -L altera_highspeed_rs_enc_151
You would then modify as follows:
ensure_lib ./libraries/_highspeed_rs_enc_151_2/
vmap       altera_highspeed_rs_enc_151_2  ./libraries/altera_highspeed_rs_enc_151_2/
eval  vlog -sv "/hs_rs_248_232_enc/altera_highspeed_rs_enc_151/sim/altera_highspeed_rs_enc_lagr_pkg.sv"  -work altera_highspeed_rs_enc_151_2
eval vsim -novopt -t ps -L work -L work_lib -L altera_common_sv_packages ... -L altera_highspeed_rs_enc_151 -L altera_highspeed_rs_enc_151_2
This problem is scheduled to be fixed in a future Quartus Prime release.
Updated 1 month ago
Version 2.0
