Knowledge Base Article
Why do I see warnings when using the 10/100/1000 Ethernet MAC with 1000BASE-X/SGMII PCS and LVDS I/O, or 1000BASE-X/SGMII PCS and LVDS I/O is selected in the Agilex™ 7 FPGA Triple-Speed Ethernet IP?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 19.4, the warnings shown will be seen when selecting the 10/100/1000 Ethernet MAC with 1000BASE-X/SGMII PCS, and LVDS I/O or the 1000BASE-X/SGMII PCS and LVDS I/O option is selected in the Agilex™ 7 FPGA Triple-Speed Ethernet IP core.
Warning: test.eth_tse_0.i_lvdsio_terminator_0.pll_areset_iopll: Associated reset sinks not declared
Warning: test.eth_tse_0.iopll: Able to implement PLL - Actual VCO frequency differs from requested setting
Warning: test.eth_tse_0.ref_clk_module.out_clk/iopll.refclk: iopll.refclk requires 125000000Hz, but source has frequency of 0Hz
Resolution
These warnings can be safely ignored as functionality is not impacted when using the Agilex™ 7 FPGA Triple-Speed Ethernet IP core.
Updated 2 months ago
Version 2.0
