Knowledge Base Article
Why do I see warnings when running Design Assistant on the F-Tile PMA/FEC Direct PHY Multirate Design Example for 50G-1 and 400G-8 Base Variant?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.3, you may see the following Design Assistant critical warnings when running the F-Tile PMA/FEC Direct PHY Multirate Design Example for 50G-1 and 400G-8 Base Variant.
- CDC-50001 1-Bit Asynchronous Transfer Not Synchronized
- CDC-50002 1-Bit Asynchronous Transfer with Insufficient Constraints
- RDC-50001 Reconvergence of Multiple Asynchronous Reset Synchronizers in Different Reset Domains
Resolution
The warnings are not harmful and can be safely ignored.
This problem is scheduled to be fixed in the future release of the Intel® Quartus® Prime Pro Edition Software
Updated 3 months ago
