Knowledge Base Article
Why do I see unconstrained Input/Output Ports at EMIF pins when I compile the Agilex™ 7 FPGA M-Series EMIF IP?
Description
You may see the unconstrained Input/Output Ports at EMIF pins when you compile the Agilex™ 7 FPGA M-Series EMIF IP.
Resolution
You can safely ignore these unconstrained warnings.  The delay values for these pins are calibrated at run-time by the EMIF firmware, and those pins do not have values in the Timing Analysis.
This problem is scheduled to be fixed in future releases of Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 2.0
