Knowledge Base Article
Why do I see U-boot hang when enabling multiple I2C controllers in I2C driver?
Description
In SOCEDS 16.1 (U-boot v2013.01.01), if you turn on the I2C multi-bus configuration within I2C driver as shown below:
#define CONFIG_I2C_MULTI_BUS 1
U-boot will hang and stop printing messages in console as shown below:
U-Boot 2013.01.01-svn7578 (Feb 01 2019 - 14:17:54)
CPU   : Altera SOCFPGA Platform
BOARD : Altera SOCFPGA Cyclone V Board
I2C:
If CONFIG_I2C_MULTI_BUS configuration is turned on, the bus_initialized static variable in I2C driver (designware_i2c.c) will be used before the BSS section get initialized.
It results in an unexpected write operation and cause the system hang.
Resolution
I2C driver (designware_i2c.c) has been updated in U-boot v2015.01 which removes the use of static variable and CONFIG_I2C_MULTI_BUS.
For multiple I2C controllers support in U-boot, please use U-boot v2015.01 or above versions.
Updated 1 month ago
Version 2.0
