Knowledge Base Article
Why do I see two different wizards for IP cores in the Quartus II software version 14.0?
Description
In the Quartus(R) II software version 14.0, you see one type of wizard when you are edit or upgrade an old IP core instance. You see a different wizard when you create a new IP core instance. In addition, the output files and directory structure depends on which wizard generates the IP core This problem affects the following IP cores:
ALTASMI_PARALLEL
ALTCLKCTRL
Altera ASMI Parallel
Altera CHIP_ID
ALTERA_FP_ACC_CUSTOM
ALTERA_FP_FUNCTIONS
ALTERA_FP_MATRIX_INV
ALTERA_FP_MATRIX_MULT
Atera Parallel Flash Loader
Altera Remote Update
Altera Serial Flash Loader
Altera Temperature Sensor
ALTOSC_INT
FIR Compiler II
Internal Oscillator
RapidIO
Reed Solomon II
Resolution
This problem has no workaround.
Updated 1 month ago
Version 3.0
