Knowledge Base Article
Why do I see timing violations in 1G/10G and 10GBASE-KR PHY FPGA IP?
Description
Due to an issue in 1G/10G and 10GBASE-KR PHY FPGA IP, Quartus® Prime Standard Edition Design Software is unable to generate SDC file along with the IP files.
Resolution
As a workaround, download the file below.
Check the following parameter values in the downloaded .sdc file and modify as per the design, if required:
- num_channels
- period_10g
- period_1g
- period_mgmt
- path_project
Updated 3 months ago
Version 4.0No CommentsBe the first to comment
