Knowledge Base Article
Why do I see the rx_control doesn't work correctly when instantiating the Transceiver Native PHY Intel® Arria® 10/Intel® Cyclone®10 GX FPGA IP as more than one channel with "Enable simplified data interface" option enabled?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.2 and earlier, the outputs of rx_control are not correct when using the Transceiver Native PHY Intel® Arria® 10/Intel® Cyclone®10GX FPGA IP in enhanced basic mode with more than 1 channel and “Enable simplified data interface” enabled.
Only the rx_control of channel 0 is right.
Resolution
This problem is fixed in the Intel® Quartus® Prime Pro Edition Software version 23.3.
Updated 2 months ago
Version 2.0
