Knowledge Base Article
Why do I see the HPS EMAC hang with RX buffer full on my Cyclone® V SoC design?
Description
Due to a problem in the Linux-socfpga kernel version 5.4 and later, the HPS EMAC may hang or stall under some circumstances.
This problem is due to an incorrect setting in the Cyclone® V SoC Linux device tree
  • The Shared Enable Override bit must be enabled on the L2C-310 Cache Controller
  • The Read and Write outstanding Transaction Limit should be set to 0xf on the EMAC DMA
Resolution
To work around this problem, perform the following steps:
1. Ensure the L2C-310  device tree node sets the shared Enable Override bit, by editing arch/arm/boot/dts/socfpga.dtsi
        L2: cache-controller@fffef000 {
            compatible = "arm,pl310-cache";
            reg = <0xfffef000 0x1000>;
            interrupts = <0 38 0x04>;
            cache-unified;
            cache-level = <2>;
            arm,tag-latency = <1 1 1>;
            arm,data-latency = <2 1 1>;
            prefetch-data = <1>;
            prefetch-instr = <1>;
            arm,shared-override;   # Check this is present
            arm,double-linefill = <1>;
            arm,double-linefill-incr = <0>;
            arm,double-linefill-wrap = <1>;
            arm,prefetch-drop = <0>;
            arm,prefetch-offset = <7>;
2.  Edit the ethernet node(s) to add a reference(s) for a snps,axi-config, and add nodes for the snps,axi-config in arch/arm/boot/dts/socfpga.dtsi
Example for GMAC0:
diff --git a/arch/arm/boot/dts/socfpga.dtsi b/arch/arm/boot/dts/socfpga.dtsi
index e404220..90a0560 100644
--- a/arch/arm/boot/dts/socfpga.dtsi
+++ b/arch/arm/boot/dts/socfpga.dtsi
@@ -560,10 +560,16 @@
        reset-names = "stmmaceth";
        snps,multicast-filter-bins = <256>;
        snps,perfect-filter-entries = <128>;
+                                                             snps,axi-config = <&stmmac_axi_setup_0>;
        tx-fifo-depth = <4096>;
        rx-fifo-depth = <4096>;
        status = "disabled";
+    stmmac_axi_setup_0: stmmac-axi-config_0 {
+        snps,wr_osr_lmt = <0xf>;
+        snps,rd_osr_lmt = <0xf>;
This problem has been fixed beginning with the linux-socfpga-5.10.120-lts and linux-socfpga-5.15.30-lts branches
Updated 3 months ago
Version 2.0
