Knowledge Base Article
Why do I see the following message during Interlaken (2nd Generation) FPGA IP and F-Tile Interlaken FPGA IP generation? Warning: ilk.ilk_f_0.mgmt_agent: Subordinate with readdatavalid must use waitrequest.
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.1, you might see the following warning message while generating the Interlaken (2nd Generation) FPGA IP and F-Tile Interlaken IP:
It is safe to ignore this message.
Resolution
No workaround is required. It is not impacting functionality.
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 23.2
Updated 3 months ago
Version 2.0
