Knowledge Base Article
Why do I see the drv_status_fail bit assert when I simulate the LPDDR2 example design in Skip Calibration mode?
Description
You may see the drv_status_fail signal assert high when you simulate the LPDDR2 example design in Skip Calibration mode. The LPDDR2 controller requires an adjustment to the DQS window, which is only provided in Quick Calibration and Full Calibration modes.Resolution
The workaround is to enable either Quick Calibration or Full Calibration mode when you generate the IP.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
