Knowledge Base Article
Why do I see the "CLK 300027 Multiple clock assignment found" DRC error on the 25 MHz and 2.5 MHz clocks from the HPS GMII to RGMII Adapter IP?
Description
Due to a problem with the Quartus Prime Pro Edition Software version 24.3.1 and earlier, you might see DRC violation "CLK 300027 Multiple clock assignment found" triggered by the HPS GMII to RGMII Adapter IP clocks 2_5M_2MUX1 and 25M_2MUX1 on Agilex 5 FPGA devices when the design includes more than one instance of the IP.
Root cause: IP SDC uses non-unique clock names and entity-level SDC binding causes constraints from each instance to apply to all instances (QS-8167 / HSD 14024594352).
Resolution
To work around this problem in the Quartus Prime Pro Edition software version 24.3.1 and earlier, in your SDC file remove the 2_5M_2MUX1 and 25M_2MUX1 clocks from the HPS GMII to RGMII Adapter IP and create unique generated clocks for each IP instance (see published KDB article for full create_generated_clock example).
The problem has been fixed starting with the Quartus Prime Pro Edition software version 26.1.
