Knowledge Base Article
Why do I see the checker error during the simulation of Interlaken (2nd Generation) FPGA IP Design Example for VHDL variants targeting Agilex™ 7 FPGA devices with the ModelSim* - FPGA Edition SE 2023.4 or Questa*- FPGA Edition?
Description
You may see the following error message during the simulation of the Interlaken (2nd Generation) FPGA IP Design Example for VHDL variants targeting Agilex™ 7 FPGA devices with the ModelSim* - FPGA Edition SE 2023.4 or Questa*- FPGA Edition.
# ________________________________________________________________# INFO: Start transmitting packets # __________________________________________________________ # # # time: 329910000 checker error count 1 # __________________________________________________________ # INFO: Stop transmitting packets # __________________________________________________________ # # # __________________________________________________________ # INFO: Checking packets statistics # __________________________________________________________ # # # time: 344203333 checker error count 25 # CRC24 errors reported: 0 # SOPs transmitted: 100 # EOPs transmitted: 100 # SOPs received: 100 # EOPs received: 100 # ECC error count: 0 # __________________________________________________________ # INFO: Test FAILED # # __________________________________________________________
Resolution
To work around this problem, please use ModelSim* - FPGA Edition SE 2023.2.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 1 month ago
