Knowledge Base Article
Why do I see stability problems with the JESD204C design examples which use the F-Tile JESD204C FPGA IP in external loopback?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 22.3, the JESD204C design examples which use the F-Tile JESD204C FPGA IP in external loopback may experience stability problems.
Depending on the exact variant you are using, these problems might manifest themselves as emb_unlock_err, sh_unlock_err, rx_gb_underflow_err, cmd_par_err, invalid_eoemb, invalid_eomb, invalid_sync_header and lane_deskew_err events.
Resolution
A patch is available to fix this problem for the Quartus® Prime Pro Edition Software version 22.3.
Download and install patch 0.11 from the appropriate link below, then re-generate your programming file.
This problem is fixed beginning with the Quartus Prime Pro Edition Software version 22.4.
Updated 8 months ago
Version 3.0
