Knowledge Base Article
Why do I see riscv-none-embed-gcc.exe: error: CMakeFiles/app.elf.dir/main.c.obj : No such file or directory after running make when building the application project for Nios® V Processor System?
Description
This is observed in the Intel® Quartus® Prime Pro Edition Software version 21.3 and onwards when building an application project for Nios® V Processor System due to incompatibility with specific Command Prompt version in Windows.
Resolution
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.3 with the steps below:
  • Use the Ninja generator, instead of the Unix Makefile generator. For example,
    1. Use cmake -G “Ninja” to replace the cmake -G “Unix Makefiles” command.
    2. Use ninja -C software/app/build to replace the make -C software/app/build command.
Use the PowerShell throughout the build process to replace the Command Prompt
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 22.1.
Updated 2 months ago
Version 2.0
