Knowledge Base Article
Why do I see recovery or removal timing violations on the automatically-created clock alt_cal_edge_detect_clk?
Description
Due to a problem in the Quartus® II software version 11.1 and earlier, a missing timing constraint on the clock alt_cal_edge_detect_clk in the transceiver logic may result in recovery and removal timing violations. The constraints for alt_cal_edge_detect_clk are automatically created by the Quartus II software.
Resolution
To work around this problem, add the following constraint to your Synopsys Design Constraints (.sdc) file:
set_clock_groups -asynchronous -group [get_clocks {alt_cal_edge_detect_clk}]
This problem is fixed beginning with the Quartus II software version 11.1 SP1.
Updated 2 months ago
