Knowledge Base Article
Why do I see receiver error and replay timer timeout from my design with the F-Tile Avalon® Streaming FPGA IP for PCI Express* on hardware?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.2, when you perform link disable, hot reset, equalization redo, or speed change (at Gen 4 and Gen 3), there is a chance of running into receiver error.
Replay timer timeout may be observed when performing L0 and L1 link state changes by means of power management.
Resolution
Receiver error and replay timer timeout are correctable errors allowed by PCI Express® specifications.
The occurrence is limited during the link operations as described above.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 23.4.1.
Updated 2 months ago
Version 2.0
