Knowledge Base Article
Why do I see read, write and erase operation failure when using the OSC_CLK_1 for Intel® Stratix® 10 devices on Macronix flash?
Description
You will see the read, write and erase operation failure when the current design runs in the FPGA using OSC_CLK_1 as the configuration clock source on Marconix flash is larger than 128Mb.
Resolution
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 18.1.1.
Updated 3 months ago
Version 2.0
